I want to count the number of records of shops within a certain category (= variable cntshops), but for some reasons the result is equal to 0. What could be the problem?
The field w_cat is a multinode treepicker of categories.
<xsl:for-each select="umbraco.library:GetXmlNodeById(1124)/* [name() = 'Categorie']"> <xsl:sort select="@sortOrder" order="ascending" data-type="number"/> <Categorie> <xsl:variable name="catid"> <xsl:text disable-output-escaping="yes">,</xsl:text><xsl:value-of select="@id"/><xsl:text disable-output-escaping="yes">,</xsl:text> </xsl:variable> <xsl:variable name="cntshops" select="count(umbraco.library:GetXmlNodeById(1132)//* [name() = 'Winkel' and contains(concat(',',w_cat,','),$catid)])"/> <xsl:attribute name="Aantal"><xsl:value-of select="$cntshops"/></xsl:attribute>
</Categorie>
</xsl:for-each>
grts,
Kim
Count number of nodes within for each
<Categorie>
</xsl:variable>
</Categorie>
</xsl:for-each>
grts,
Kim
