We are using umbraco 4.7.0. and we are facing some issues by saving the css files into database.
What is happening:
I changed the name of the css file with the umbraco backend but inside the database (dbo.cmsStylesheet) it does not update the name in the way i have specified.
Umbraco backend shows the correct name.
Is there any known issue?
Every time I try to create a package with courier it is using the database css name which does not exist as file!
CSS Saving database issue - important
What is happening:
It looks like that the column "filename" column does not get updated.
Can somebody help please?
