I want to go through each media folder and look for the value of a custom property i've made, "mycustomproperty". How can I do this in the codebehind/api?
I tried
var foundNodes = root.GetDescendantNodes().Where(x => x.GetPropertyAsString("mycustomproperty").Contains(searchString));
And what type of variable is 'root'? I think GetDescendantNodes might only work for Content nodes. Something like this should work for Media (in 4.9.0 with uQuery built in)
var root = new Media(xxxx); var foundNodes = root.GetDescendantMedia().Where(x => x.GetProperty<string>("myValue").Contains(searchString));
Search mediafolders for a property?
I tried
But it returns null.
Pete
What version of Umbraco are you using?
Hope this helps,
Tom
Hi Tom
Thanks for the reply. I'm on 4.7.2. I've got uComponents/uQuery installed.
For root I was using:
umbraco.NodeFactory.Node root = umbraco.NodeFactory.Node.GetCurrent();
What do you set for the root? -1? will that make it go through all the media nodes?
Not sure how you can start at the media root, but you could try this instead:
var medias = uQuery.GetMediaByType("Image").Where(x => x.GetProperty<string>("myValue").Contains(searchString));-Tom
That did it, many thanks tom.
