The fields you see are controlled by the settings of that particular Document Type. To adjust those, you can goto Settings -> Document Types. After clicking on a specific document type, click the Generic Properties tab to see which properties make up that document type. From there you could add a new one using the Datatype "Richtext Editor", or change your existing Text box field to this.
That's strange, are you trying to enter HTML into a non-Richtext field or is that the content you entered into the RTE? This error can happen if you try to enter HTML into a textbox, for example.
i simply typed some test and hit "save and publish"...
some more information though.. not sure if it's relevant...
I am developing this with anther person and we work remotely. the database for umbraco is sitting on an azure database and the code is local to our machines using TFS.
could that be anything to do with the problem possiby?
Enable Rich Text Editor?
New to umbraco so apologies.
A friend has setup an umbraco site for me and left me to play with it for a while.
He has created a page and I can add content to a section within the page but it's just a standard text box so I cannot add any formatting.
Do I need to do something to enable the rich text editor?
Can anyone tell me how to do this please?
Trev
Hi Trev,
For more info on how this works, you might want to check out some of the free umbraco.tv videos here: http://umbraco.com/help-and-support/video-tutorials/introduction-to-umbraco.aspx
Hope this helps,
Tom
Hi, thanks, found that option and changed it.
I then went back to the page and added some extra content and tried to publish the page and now I get this error:
A potentially dangerous Request.Form value was detected from the client (ctl00$body$prop_hTML="<p>TaxiRoute is a Ta...").
I only changed what you said.
Trev
Hi Trevor,
-Tom
trev
Hi trev,
I don't think that should be an issue, it sounds more like the webserver than the database.
Are you using the stock Umbraco web.config? In particular I think this line could affect things - it should be as listed below
<httpRuntime requestValidationMode="2.0" />HTH,
Tom
