  • Barry 99 posts 187 karma points
    Aug 15, 2009 @ 16:13
    Barry
    Strange Stylesheet saving issue
    When I paste in changes and save them, they appear on the site fine. However, when I go to the interface and open the stylesheet - its the old version shown, so if I made a change and save it - it will revert changes I made before. I tried doing my changes, logging out and logging back in again but the stylesheet remains the "old" version even though the website displays correctly.
    Any ideas?
    I am editing in FF3.5
    Umbraco 4.0.2
    SQL Server 2008
  • Douglas Robar 3570 posts 4711 karma points MVP ∞ admin c-trib
    Aug 15, 2009 @ 16:28
    Douglas Robar
    When you say you paste in changes... do you mean you open the files in an editor directly from the files on the filesystem, or from within the umbraco admin interface? I suspect from the filesystem and your editor is locking the file so umbraco can't keep it in sync with the internal editor. If you close the external editor and then open the css file from within umbraco, do you see the proper version?
    cheers,
    doug.
    Aug 15, 2009 @ 16:32
    Barry
    No, via the Umbraco interface just pasting in the stylesheet from an external editor (Stylizer).
    Aug 15, 2009 @ 16:50
    Barry
    It seems to be chopping of this
    /*EDITOR PROPERTIES - PLEASE DON'T DELETE THIS LINE TO AVOID DUPLICATE PROPERTIES*/
    .eventinfo A, A.visited, A.Hover
        color: #31CAFD;
        font-weight: bold;
        font-size: 1em;
    It says Stylesheet saved correctly.. and it shows correctly but when re-opened it looks like it is not opening the file "as is".
  • Kyle Skrinak 272 posts 327 karma points
    Aug 15, 2009 @ 17:27
    Kyle Skrinak
    Have you run your source stylesheet through W3C to find validation errors?
  • Chris Koiak 700 posts 2626 karma points
    Aug 16, 2009 @ 10:26
    Chris Koiak
    What if you try moving the ".eventinfo A, A.visited, A.Hover" line to before the comment? Or try adding a new line after the comment?
    Does this happen with all css files you eidt, or just this one?
    Aug 17, 2009 @ 14:11
    Douglas Robar
    The build-in css editor hides the
    section at the bottom of the css file, as these are the 'stylesheet properties' that appear when you add styles to the dropdown list in the RTE.
    You edit these properties via the treeview control by expanding the stylesheet and css file. This is a difference between working with the raw file on the filesystem and working with the css file via the umbraco admin interface.
    cheers,
    doug.
