  • Scott Drummond 9 posts 35 karma points
    Oct 24, 2012 @ 17:05
    Scott Drummond
    alternative to uComponents: Xpath Checkboxlist
    I am  currently using a uComponents: Xpath Checkboxlist Data Type to allow people to select a what categories are relevant to given node.
    The client has now asked to upgrade this to allow each category to be rated 0-10, instead of a checkbox.
    Am I missing a trick in the normal or ucomponent datatypes to do this, or do I have to build a custom datatype using the usercontrol wrapper?
    I am currently using Umbraco 4.7.2. and uComponents 2.1.
    Scott
  • Mike Chambers 636 posts 1253 karma points c-trib
    Oct 25, 2012 @ 10:07
    Oct 25, 2012 @ 10:32
    Scott Drummond
    Hi Mike,
    Basically a multiple version of that is what I'm after.
    Ideally I'd set up some prevalues in the datatype, and for each value I'd have a slider to rate it 1-10.
    This would be stored as xml to allow the values to be called from XSLT.
    The alternative is to create some database tables, some custom editors in the backed and a .net usercontrol that will do the filtering and displaying on the front end. This is easy enough to do, but i am wondering its not the .net way and not the 'most umbraco' way of doing it.
    Scott
