I'd like to better understand how "umbraco users" works.
I'm using Umbraco 4.0.2.1, and I'd like to use the standard ASP.NET membership provider, instead of using the umbraco one.
I modified "web.config/.../membership" and "umbracoSettings.config/.../DefaultBackofficeProvider" to point to the ASP.NET membership provider (with my own connection string that points to another DB).
I login to umbraco using admin built-in administrator (the same user already exists in the asp.net membership database, so I can do it).
When I try to create a new user in "Users" nothing happens.
Why this happen?
I'd like to know what happen when I create a new User... and what is the link beetwen Umbraco Users and Memberhip Users
In umbraco there are Members and Users. Both are completely different and have nothing to do with each other.
Users in umbraco are used for back-end access. Members are used for the front-end. My guess is that you want member-functionality, so you should be looking at the member-section, not the user-section.
The membership-provider can only be used for the front-end.
But, now I'm trying to keek the default in "umbracoSettings.config/.../DefaultBackofficeProvider" and my own Membership provider in "web.config/.../membership"
When I create a new user in "Users" using an existing username in membership... values like the email address are showed in the edit user form!
So, as you see... there is still a link between Users and Membership!
understanding umbraco users
Why this happen?
Thanks you so much
Stefano
Does this clear things a bit?
HTH
Peter
Hi Peter,
thanks for your answer.
This is clear.
How is it possible?
