  • oran 9 posts 29 karma points
    Oct 31, 2012 @ 09:45
    oran
    try to chanage the admin style
    I used umbraco 4.9.1 and I try to change the admin style in umbraco/css/umbracoGui.css
     It does not affect. There is another file I need to change?
  • sun 403 posts 395 karma points
    Oct 31, 2012 @ 10:01
    sun
    using Chrome, you can use F12 to see which css/javascript are using currently.
    Oct 31, 2012 @ 10:05
    Dirk De Grave
    most of css/js in backend are combined and minified using the clientDependency framework... so you may need to clean out folder where your clientdependency files are stored or change version number of client dependency
    Files are stored in /App_Data/ClientDependency or /App_Data/TEMP/ClientDependency
    Client dependenct version number can be changed in file /config/clientdependency.config
    /Dirk
    Oct 31, 2012 @ 10:23
    oran
    Thank you Dirk,
    Really helped me :)
