When I add a style sheet to the RTE. The options appear in the style select menu and the correct styling is applied to the relevant html elements. The aliases I'm using are p, h2, h3 and h4.
It use to be that when you clicked on an element in the RTE the style select menu was updated to show the style rule which was being applied to the selected element. I.e if I clicked on a 'p' tag then 'Paragraph' would be the selected item in the style dropdwon menu. This no longer happens and so I'm not sure if this is a recent change - so thought I would check.
RTE selected style in drop down menu
The version of Umbraco is 4.9.0.
Eddie
