I've logged in as a user into the backend, enabled notifications on publish and published a page but didn't recieve any notification email.
I've checked the following
Local SMTP server is running
SMTP is sending mail
UmbracoSettings.config does have a notifications email address
web.config has got the SMTP server settings configured properly
Not sure if this has anything to do with it but you can see in the image. there's more than one sort tickbox
We're tunning Umbraco 4.7.2 on.NET 4.0.30319 on a SQL server express 2008 database on windows server 2008 server.
It isn't a virgin umbraco install, it's been upgraded from 4.5 but has been sending emails since the upgrade, the notification feature has never been used before.
Problem Receiving Notification Emails
