  • dominik 711 posts 733 karma points
    Nov 13, 2012 @ 17:05
    dominik
    Restrict Useraccount
    hello,
    we have the following structure in our content section
    - en
      - Page1
      - Careers
        - subCareers
    - de
       - Page 1
       - Careers
         - subCareers
    Now i only want to allow the access to the "Careers" section for a specific user.
    I tried by setting the start node to 'en - Careers' but this will not show the german tree "de - Careers" of course.
    Is there any way to allow only specific sections within the full tree for specific users?
    Nov 13, 2012 @ 20:47
    Hi Dominik
    Perhaps you should try looking at the User group permission package - this will allow you to define access on a node basis in the content section.
    Be aware that the current version (as far as I know) is not yet compatible with v4.9+ though...but if you politely ping Richard on Twitter then he'll perhaps send you an updated version, which is.
    Hope this is what you're looking for.
    Nov 14, 2012 @ 08:17
    dominik
    HI Jan,
    Is there also any other way how i can achieve this without using a third party tool?
    Perhaps the user will see all of the other pages but is not allowed to save or publish them?
    THanks
    Nov 14, 2012 @ 20:57
    Hi Dominik
    Not that I can think of currently. I've been using the above package succesfully previously.
    Otherwise I think you should try doing some custom stuff using the API perhaps but I think that's a much bigger task :)
