  • SiKo279 82 posts 238 karma points
    Aug 20, 2009 @ 10:47
    SiKo279
    Related links, recursive... trouble
    First off, I think Umbraco is great. Extensible, fast, etc.
    But this XSLT thing is biting me everytime I even point at it. :(
    Anyway, I want to define on the top node some Related Links, that need to appear on every page on the site.
    So, I found this post: http://our.umbraco.org/forum/developers/xslt/3331-Related-Links-Recursive
    But for some reason, it does not list the links, I added in the related links property on the top node (alias='servicesLinks')
    [code]
    <xsl:template match="/">
      <h2>Services</h2>
        <!-- The fun starts here -->
         <ul>
          <xsl:for-each select="$currentPage/ancestor-or-self::node [count(data[@alias='servicesLinks']/links/link)&gt; 0] [1] /data[@alias='servicesLinks']/links/link">
            <li>
              <xsl:element name="a">
                <xsl:if test="./@newwindow = '1'">
                  <xsl:attribute name="target">_blank</xsl:attribute>
                </xsl:if>
                <xsl:choose>
                  <xsl:when test="./@type = 'external'">
                    <xsl:attribute name="href">
                      <xsl:value-of select="./@link"/>
                    </xsl:attribute>
                  </xsl:when>
                  <xsl:otherwise>
                      <xsl:value-of select="umbraco.library:NiceUrl(./@link)"/>
                    </xsl:attribute>
                  </xsl:otherwise>
                </xsl:choose>
                <xsl:value-of select="./@title"/>
              </xsl:element>
            </li>
          </xsl:for-each>
        </ul>
        <!-- Live Editing support for related links. -->
        <xsl:value-of select="umbraco.library:Item($currentPage/@id,$propertyAlias,'')" />
      </xsl:template>
    [/code]
    All suggestions are welcome!
    SiKo279
    [code]<xsl:template match="/">
      <h2>Services</h2>
         <ul>
            <li>
                </xsl:if>
                <xsl:choose>
                    </xsl:attribute>
                  </xsl:when>
                  <xsl:otherwise>
                    </xsl:attribute>
                  </xsl:otherwise>
                </xsl:choose>
              </xsl:element>
            </li>
          </xsl:for-each>
        </ul>
      </xsl:template>
    [/code]
    SiKo279
    Aargh!!! We need an edit function!!!
    Aug 20, 2009 @ 10:48
    SiKo279
      <h2>Services</h2>
         <ul>
            <li>
                </xsl:if>
                <xsl:choose>
                    </xsl:attribute>
                  </xsl:when>
                  <xsl:otherwise>
                    </xsl:attribute>
                  </xsl:otherwise>
                </xsl:choose>
              </xsl:element>
            </li>
          </xsl:for-each>
        </ul>
      </xsl:template>
    Aug 20, 2009 @ 13:13
    SiKo279
    I reposted this in the developers forum/xslt.
  • Bert 128 posts 251 karma points
    Aug 20, 2009 @ 15:25
    Aug 20, 2009 @ 15:28
    Bert
    nvm wrong paste
    Aug 25, 2009 @ 10:17
    SiKo279
    Yeah, I copied your solution, but didn't get it to work...
    Aug 26, 2009 @ 13:38
    Bert
    Strange worked here. Got some troubles with the live editing, but just deleted that functionality
    Aug 27, 2009 @ 09:01
