  • shufflemoomin 37 posts 36 karma points
    Aug 20, 2009 @ 12:22
    shufflemoomin
    umbracoRedirect?
    Hi Everyone,
    I had a site running in Umbraco 3 that used an umbracoRedirect property. In version 3, the URL was shown like this: www.home.com/english/page.aspx but now on version 4 the URL is being shown as www.home.com/page.aspx, even though it is still under a node called 'english'. This throws off any hard coded urls. Is there any way to change the umbracoRedirect to show the URLs as it did in version 3?
    Thanks for any help
    Aug 20, 2009 @ 12:31
    Dirk De Grave
    Are the setting for umbracoHideTopLevelNodeFromPath (in web.config) the same in both installs?
    /Dirk
  • SiKo279 82 posts 238 karma points
    SiKo279
    the umbracoUrlName document type property defines the url. if you specify english/page the url will be <domain>/english/page.aspx
    the umbracoUrlAlias document type property defines alternatives for the url. if you specify test/test ; bla/page, the page will be reachable under <domain>/bla/page.aspx and <domain>/test/test.aspx
    Hard coded url are not a good idea in general. Better to replace them with {localLink:(nodeID)}. E.g. href={localLink:1258}
    HTH
