  • nojaf 91 posts 300 karma points
    Nov 23, 2012 @ 14:13
    nojaf
    TinyMCE doesn't save all text
    Hello,Every time I typ a long part of text in the TinyMCE, it won't save all my text but only the first part.How can I fix this?I'm using v4.10 and mySQL.
    Nov 23, 2012 @ 20:13
    Hi nojaf
    What browser do you experience this in?
    Nov 25, 2012 @ 15:24
    nojaf
    IE10 and Chrome, it don't think its a browser issue
    Nov 25, 2012 @ 21:35
    Hi Nojaf
    Nope, not sure that it is but it's an odd issue and I don't recall seeing or hearing about this before so that's why I'm trying to explore the options :)
    Maybe it can be related to the use of MySQL for instance. But have you checked if you get any error messages in the browser console when trying to save content? And have you checked if something usefull is written to the umbracoLog table in the database?
    Looking forward to hearing from you.
    Nov 27, 2012 @ 14:51
    nojaf
    When I look at the Chrome javascript console before the save and publish I see this
    Failed to load resource: the server responded with a status of 500 (Internal Server Error)
    http://mysite.com/umbraco/webservices/CheckForUpgrade.asmx/CallUpgradeService
    Nothing strange happening after the save and publish.
    There is nothing in my umbracoLog table that's even close to the date of saving.
    I did see the following errors but I'm not sure if they are relevant.
    27 0 -1 2012-11-01 22:10:37 Error Error loading actionhandler 'umbEnsureUniqueName': System.InvalidCastException: Unable to cast object of type 'System.Byte[]' to type 'System.IConvertible'.
      at MySql.Data.MySqlClient.MySqlDataReader.GetInt32(Int32 column)
      at umbraco.DataLayer.RecordsReaderAdapter`1.GetInt(String fieldName)
      at umbraco.cms.businesslogic.web.Document.PopulateDocumentFromReader(IRecordsReader dr)
      at umbraco.cms.businesslogic.web.Document.GetChildrenBySearch(Int32 NodeId, String searchString)
      at umbraco.ActionHandlers.umbEnsureUniqueName.Execute(Document documentObject, IAction action)
      at umbraco.BusinessLogic.Actions.Action.RunActionHandlers(Document d, IAction action)
    29 0 -1 2012-11-01 22:10:40 Error At /umbraco/webservices/TreeDataService.ashx?rnd=c9bc880d13444ac694da680b1480fce0&id=-1&treeType=content&contextMenu=true&isDialog=false&rnd2=76.4 (Referred by: http://localhost:12054/umbraco/umbraco.aspx#content):
