I'm trying to override the standard formatting options for tinyMCE using style_formats, I've looked up how to on the tinyMCE forums but there seems to be no information on how to add such overrides in Umbraco. The usual method is to add it in the tinymce.init() method.
People refer to the tinymceconfig.config file, but I have no clue as to where I have to put my code there. My first guess was in CDATA, for obvious reasons, but it doesn't seem to affect my styles at all.
<invalidElements>font</invalidElements>
<!-- this area is for custom config settings that should be added during TinyMCE initialization --> <![CDATA[', style_formats : [ {title : 'Arial', inline : 'span', attributes : { 'class' : 'arial'}}, {title : 'Helvetica', inline : 'span', attributes : { 'class' : 'helvetica'}}, {title : 'Tahoma', inline : 'span', attributes : { 'class' : 'tahoma'}}, {title : 'Times New Roman', inline : 'span', attributes : { 'class' : 'times'}}, {title : 'Trebuchet', inline : 'span', attributes : { 'class' : 'trebuchet'}}], ]]> <customConfig>
Of course, it could be that my syntax is screwed up in this context, but I don't get any feedback from tinyMCE regarding that.
Adding initialization options to TinyMCE
like this
<customConfig> <!-- <config key="myKey">mySetting</config>--> <config key="entity_encoding">raw</config> <config key="spellchecker_rpc_url">GoogleSpellChecker.ashx</config> <!-- START ADDED --> <config key="theme_umbraco_path">true</config> <config key="theme_umbraco_statusbar">true</config> <config key="theme_umbraco_statusbar_location">bottom</config> <config key="template_external_list_url">/scripts/vendor/tinyMCETemplates/templates.js</config> <config key="template_popup_height">400</config> <config key="theme_umbraco_blockformats">p,h2,h3,h4,address,pre</config> <config key="theme_umbraco_styles">;list-alphabetical=.list-alphabetical;list-roman=.list-roman;</config> <!-- END ADDED --> </customConfig>ps left a few other amends we make to bring useful tinymce elements back into the fold
Ah, thanks. Yeah, this seems to work. Most examples I found just used Javascript.
