We want to build a mobile site which supports phones and tablets. Since tablets have a bigger screen we want to build separate HTML for it, but without using a responsive design. The site will be one tree in Umbraco so we're thinking about switching between templates based on the capabilities of the device. I saw this: http://www.hanselman.com/blog/NuGetPackageOfTheWeek10NewMobileViewEnginesForASPNETMVC3SpeccompatibleWithASPNETMVC4.aspx and was wondering if this was the way to go using Umbraco 4.11. Are there any thoughts on what's the way to go for this?
For now i added a 'master' controller which all my custom controllers (which build a custom model in 90% of the pages) inherit from. In that controller i have the following to do the switch between templates. For the mobile capability detection we're using http://blog.mobileesp.com/
public class BaseController : Umbraco.Web.Mvc.RenderMvcController
public override ActionResult Index(RenderModel model)
var context = System.Web.HttpContext.Current;
var currentTemplate = base.ControllerContext.RouteData.Values["action"].ToString();
if (currentTemplate.Contains("MobilePhone"))
//user is in mobile site and can be redirected
var mobileDetection = new MobileDetection(context);
if (mobileDetection.DetectTierTablet())
var newTemplate = currentTemplate.Replace("MobilePhone", "MobileTablet");
if (this.EnsurePhsyicalViewExists(newTemplate))
//it's a tablet, return the alternate tablet-view
return View(newTemplate, model);
return base.Index(model);
Look at something like Twitter Bootstrap that will allow you to create a Responsive Design website where no matter what your resolution of the phone/tablet/screen, you can have a design that matches it without having to create new templates.
Mobile template in 4.11
Hi all,
have you looked at http://51degrees.mobi/?
You can serve different paths to different devices depending on detection .... [say that 10 times fast!]
Hope this helps!
J
public class BaseController : Umbraco.Web.Mvc.RenderMvcController { public override ActionResult Index(RenderModel model) { var context = System.Web.HttpContext.Current; var currentTemplate = base.ControllerContext.RouteData.Values["action"].ToString(); if (currentTemplate.Contains("MobilePhone")) { //user is in mobile site and can be redirected var mobileDetection = new MobileDetection(context); if (mobileDetection.DetectTierTablet()) { var newTemplate = currentTemplate.Replace("MobilePhone", "MobileTablet"); if (this.EnsurePhsyicalViewExists(newTemplate)) { //it's a tablet, return the alternate tablet-view return View(newTemplate, model); } } } return base.Index(model); } }Any more thoughts on how it's solved?
