  • Roger 195 posts 474 karma points
    Dec 12, 2012 @ 17:51
    Roger
    Edit standard asp:login control
    I am using the standard login control on my site to allow users to access protected pages.
    I need to edit the label text and the styles of the control
    Can anyone tell me where I can access the control or do I need to add some kind of view control to edit it?
    Thanks!
    Dec 12, 2012 @ 18:03
    Roger
    Or do I need to edit in VS and convert to a template?
    Dec 12, 2012 @ 18:13
    Roger
    Ah i've sorted it by adding attributes to the control :)
    Tom Fulton
    The ASP.NET login control has some attributes you can use to adjust certain things, for exampke LoginButtonText="Login" or UserNameLabelText="Your Username" etc.  See the full list here
    Also, I've found that depending on your needs, it can be very difficult to get the Login control styled exactly how you like.  There's plenty of articles on google about this if you're having trouble, but an alternative is to use the RazorLogin package, which gives you full control over the markup.
    Hope this helps,
    Tom
    Dec 12, 2012 @ 18:15
    Roger
    Thanks Tom, i think i just sussed out the attributes. The rest i'll do with styles
    Thanks again
    Roger
