The challenge is to upgrade the site and retain these URLs - including the legacy display of products, and mapping between the slug (e.g "toy-mouse") and the product.
I've created a page called "Product" in Umbraco, and on this page I embed a user control which displays the Product details just as they were in the old system. But how do I point "product/*" to this page, where "*" is anything?
If I use a query string parameter instead (e.g. tempuri.org/product?toy-mouse) this is easy, but as mentioned above I must retain the original URLs.
Your help is hugely appreciated!
Gary
(apologies if this shows up twice; my line breaks were munged and the editing feature currenty breaks on submit)
Mapping wildcard paths for routing in Umbraco
Hi there,
I'm updating a legacy site to use Umbraco. For its product inventory, it uses URLs such as the following:
http://tempuri.org/product/toy-mouse
http://tempuri.org/product/inflatable-duck-with-hat
http://tempuri.org/product/talking-scorpion
Gary
Hi again,
Can anyone point me in the right direction to figure out this issue?
All advice massively appreciated and desperately sought :)
Gary
This should be possible by using url rewriting, you could play around with that.
in the config file UrlRewriting.config add something like
<add name="ProductRewite" virtualUrl="~/product/(.*)$" rewriteUrlParameter="ExcludeFromClientQueryString" destinationUrl="/product?name=$1" ignoreCase="true" />
Hope this helps!
Thanks Stephen Roberts, you cool cat.
