I have an umbraco v 4.11.1 (Assembly version: 1.0.4715.27659) instalation
I try to get related links to work
I have an XSLT file i have used several times, but now i vill not vork any more
XSLT:
<!-- Input the related links property alias here --> <xsl:variable name="propertyAlias" select="string('footerLinks')"/> <xsl:template match="/"> <!-- The fun starts here --> <ul> <xsl:for-each select="$currentPage/ancestor-or-self::*[@level = 1]/*[name() = $propertyAlias]/links/link"> <li> <xsl:element name="a"> <xsl:if test="./@newwindow = '1'"> <xsl:attribute name="target">_blank</xsl:attribute> </xsl:if> <xsl:choose> <xsl:when test="./@type = 'external'"> <xsl:attribute name="href"> <xsl:value-of select="./@link"/> </xsl:attribute> </xsl:when> <xsl:otherwise> <xsl:attribute name="href"> <xsl:value-of select="umbraco.library:NiceUrl(./@link)"/> </xsl:attribute> </xsl:otherwise> </xsl:choose> <xsl:value-of select="./@title"/> </xsl:element> </li> </xsl:for-each> </ul> <!-- Live Editing support for related links. --> <xsl:value-of select="umbraco.library:Item($currentPage/@id,$propertyAlias,'')" /> </xsl:template>
<ul class="footer-items-list"> <li> <a href="/">Hundefrisør</a> </li> <li> <a href="/">Hundesalon</a> </li> <li> <a href="/tidsbestilling.aspx">Tidsbestilling</a> </li> </ul>
I get this output when i insert the macro into my template:
<links> <link title="Hundefrisør" link="1056" type="internal" newwindow="0" /> <link title="Hundesalon" link="1056" type="internal" newwindow="0" /> <link title="Tidsbestilling" link="1080" type="internal" newwindow="0" /> </links>
Any ideas?
(I have been trying for hours now... i´m sure this is a small isue, but i cant see it)
Tanks in advance. :-)
Comment author was deleted
Are you sure you are outputting the correct macro since it looks like the stored data
Tanks... Sorry my fault, i had put the Umbraco pagefield related links... instesd of the macro :-)
Some times it is difficult to see, my own errors
René
Related Links
XSLT:
<!-- Input the related links property alias here --> <xsl:variable name="propertyAlias" select="string('footerLinks')"/> <xsl:template match="/"> <!-- The fun starts here --> <ul> <xsl:for-each select="$currentPage/ancestor-or-self::*[@level = 1]/*[name() = $propertyAlias]/links/link"> <li> <xsl:element name="a"> <xsl:if test="./@newwindow = '1'"> <xsl:attribute name="target">_blank</xsl:attribute> </xsl:if> <xsl:choose> <xsl:when test="./@type = 'external'"> <xsl:attribute name="href"> <xsl:value-of select="./@link"/> </xsl:attribute> </xsl:when> <xsl:otherwise> <xsl:attribute name="href"> <xsl:value-of select="umbraco.library:NiceUrl(./@link)"/> </xsl:attribute> </xsl:otherwise> </xsl:choose> <xsl:value-of select="./@title"/> </xsl:element> </li> </xsl:for-each> </ul> <!-- Live Editing support for related links. --> <xsl:value-of select="umbraco.library:Item($currentPage/@id,$propertyAlias,'')" /> </xsl:template><ul class="footer-items-list"> <li> <a href="/">Hundefrisør</a> </li> <li> <a href="/">Hundesalon</a> </li> <li> <a href="/tidsbestilling.aspx">Tidsbestilling</a> </li> </ul>I get this output when i insert the macro into my template:
<links> <link title="Hundefrisør" link="1056" type="internal" newwindow="0" /> <link title="Hundesalon" link="1056" type="internal" newwindow="0" /> <link title="Tidsbestilling" link="1080" type="internal" newwindow="0" /> </links>Any ideas?
René
