  • Carlos 338 posts 472 karma points
    Dec 20, 2012 @ 00:18
    Carlos
    How do you get Prevalues from a Datatype using Razor
    It used to be so easy to just get your prevalues from a datatype in XSLT.  1 line!!!
    What has happened and what is the easiest way to get the prealues from a dropdown list datatype using Razor?
    This is my XSLT code, how can I get it in Razor????
    <select name="Grades" id="teachersResourceSearchGrade">
    <option value="">Choose Grade</option>
    <xsl:for-each select="umbraco.library:GetPreValues(10610)//preValue">
    <xsl:choose>
    <xsl:when test="$resourceGradeType=@id">
    <option value="{.}" disabled="false"><xsl:value-of select="." /></option>
    </xsl:when>
    <xsl:otherwise>
    </xsl:otherwise>
    </xsl:choose>
    </xsl:for-each>
    </select>
  • Sören Deger 733 posts 2844 karma points c-trib
    Dec 20, 2012 @ 07:25
    Sören Deger
    Hi Carlos,
    this can help you:
    http://our.umbraco.org/forum/developers/razor/32176-get-prevalue-text-from-dropdown
    Sören
    Dec 20, 2012 @ 18:54
    Carlos
    @Soren,
    That gets the prevalue for a dropdown that is a Property of the current Model.  I need it for the ID of the Datatype not the property of the Model.  In the example I put up it is getting the ID (10610)  of the custom Datatype itself not the @Model.Property.
    Thanks though.
