  • TimH 5 posts 25 karma points
    Dec 20, 2012 @ 12:06
    TimH
    Razor and media question, how do I display an image that has been uploaded in the Media section?
    I searched around and found absolutely nothing like what I was expecting, some XSLT stuff that's not for me and some other code that made no sense as it was out of context.Here's what I have:A jpg uploaded into Media sectionA document type with a media picker property called mylogo.The corresponding razor template that I want to use this jpg in.I came up with this:@using umbraco.cms.businesslogic.media...<img src="@(new Media(int.Parse(Umbraco.Field("mylogo").ToString())).GetImageUrl())" />Is there any better / easier way of displaying an image, this seems such a basic thing to want to do?Cheers.
  • Morten 20 posts 61 karma points
    Dec 20, 2012 @ 12:32
    Morten
    var media = Model.NodeById(Model.MyLogo);
    @:<img src="@media.NiceUrl" alt="" />
     // or
    @:<img src="@media.umbracoFile" alt="" />
    Dec 20, 2012 @ 12:41
    Jeroen Breuer
    You could try the DAMP Gallery. It's an image gallery and the complete source is available so you can see exactly how it works.
    Jeroen
    Dec 20, 2012 @ 12:52
    TimH
    Sorry about the formatting there, tried to correct it, failed.
    Thanks for the replies so far.
    @Morten:
    My page @inherits Umbraco.Web.Mvc.UmbracoTemplatePage
    So it doesn't look like I have access to the Model in that way, do I need to do something different?
    @Jeroen: I'll take a look at the code, cheers.
    Dec 20, 2012 @ 13:58
    TimH
    I looked, couldn't find anything in DAMP that I could follow or how I could use it in my template, I don't really need an image gallery, just one image URL from the Media.
    Sure, new Media(int.Parse(Umbraco.Field("mylogo").ToString())).GetImageUrl() that I have will work, I'm just looking for a shortcut way of doing this.
    Dec 20, 2012 @ 14:03
    Jeroen Breuer
    Don't use "new Media()". It's really slow to use. Use TypedMedia or Media in the UmbracoHelper: http://our.umbraco.org/documentation/Reference/Mvc/views
    Example:
    var media = @Umbraco.TypedMedia(id);
    More info here: http://umbraco.com/follow-us/blog-archive/2012/10/30/getting-started-with-mvc-in-umbraco-410.aspx
    Jeroen
    Dec 20, 2012 @ 16:01
    TimH
    Thanks for the heads-up, I then found this:
    http://our.umbraco.org/documentation/Using-Umbraco/Backoffice-Overview/Property-Editors/Built-in-Property-Editors/Media-Picker
    Which also shows a use of Umbraco.Media for the dynamic equivalent.
    I might have to write my own helper to shortcut this.
    Thanks for your time.
    Tim
