  • Rick 34 posts 83 karma points
    Aug 24, 2009 @ 16:46
    Rick
    Umbraco and Webparts
    Is it possible to write webparts for use in umbraco? I want users to be able to move datatypes around in the canvas editing view. This way they can customize and not have to just use pre-defined templates for layout.
    Rick
    Aug 24, 2009 @ 16:47
    Ismail Mayat
    Rick,
    Take a look at http://our.umbraco.org/projects/widgetframework project although this is not used in canvas it may be give you some ideas.
    Regards
    Ismail
  • Chris Koiak 700 posts 2626 karma points
    Aug 24, 2009 @ 16:54
    Chris Koiak
    Hi Rick,
    If your interested in the WidgetFramework source I can email it to you.
    I believe it is also in the 4.1 (maybe v5) plan to incorporate widgets into the Umbraco Dashboard.
    Chris
    Aug 24, 2009 @ 17:10
    Rick
    Tried the demo and this is exactly what I am looking for! Can the user save the layout after widgets are moved?
    Aug 24, 2009 @ 17:15
    Chris Koiak
    The layout changes are saved as soon as the move/drop happens.
    Try moving a widget and then refreshing the page, the widget will be in the new location.
    Watching the ajax calls via Firebug will help you work out what's happening.
