Our marketing people just asked me how they are able to find out which media items are referenced from which site. For example if they want to delete a pdf document they want te ensure that the item is not referenced before deleting it.
Is there a way how they can check if it is used by any content page?
I can search for the ID within the umbraco.config file but this is not a solution for the marketing as they are just using the umbraco backend.
Check for unused/used media items
Any suggestions?
dominik,
There was a package done by the farm but it only works on older versions of umbraco http://our.umbraco.org/projects/backoffice-extensions/thefarm-media-link-checker ideally we need the source and it needs updating so that it works in later umbraco versions.
Regards
Ismail
HI Ismail,
I could not believe that there is no one else who is facing the same problem because the database is getting bigger and bigger.
We are using umbraco version 4.7.2
