I then use this package to make a permanent redirect to the frontpage node (Forside).
If a choose a node with the content picker for a node, which haven't configurated hostnames it redirect fine to the chosen node.
I have tried to set * and http://vejstrup.dk.nt15.unoeuro-server.com to the domain on the "da"-node but when choose frontpage node it should redirect to,it doesn't seem to redirect.
I have done the setup before in 4.9.x and previous version where it worked.
But I also noticed that when I set the domain on "da"-node the frontpage get this url: /forside.aspx ... in previously versions of Umbraco (4.9.x) with same structure I got /da/forside.aspx
has anything changed on this? or am I doing something wrong?
What version of Umbraco is this? Is it also 4.9 or is it a newer version? The request pipeline has been rewritten and in 4.10 I believe there where some bugs, which was sorted in 4.11 so if this is 4.10 that might be the issue?
Permanent redirect and manage hostname
Hi..
I have the following node stucture in Umbraco:
/Bjarne
Hi Bjarne
Looking forward to hearing from you.
Hi Jan
Sorry for missing that part. This installation in running on v. 4.11.1
/Bjarne
