  • Kate 267 posts 610 karma points
    Jan 16, 2013 @ 15:11
    Kate
    umbraco.library:GetMedia problem
    I dont understand why I get an error in this kode.
    If I ignore errors it works fine.
    The code looks lige this
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
    version="1.0"
    <xsl:template match="/">
    <xsl:variable name="media" select="umbraco.library:GetMedia($currentPage/testBillede, 0)" />
    <xsl:if test="$media != ''">
    <xsl:variable name="url" select="$media/umbracoFile" />
    <xsl:variable name="width" select="$media/umbracoWidth" />
    <xsl:variable name="height" select="$media/umbracoHeight" />
    <img src="{$url}" width="{$width}" height="{$height}" />
    </xsl:if>
    </xsl:template>
    </xsl:stylesheet>
    And the error like this
    Error occured
    System.OverflowException: Value was either too large or too small for an Int32.
    at System.Convert.ToInt32(Double value)
    at System.Double.System.IConvertible.ToInt32(IFormatProvider provider)
    at System.Convert.ChangeType(Object value, Type conversionType, IFormatProvider provider)
    at System.Xml.Xsl.Runtime.XmlQueryRuntime.ChangeTypeXsltArgument(XmlQueryType xmlType, Object value, Type destinationType)
    at System.Xml.Xsl.Runtime.XmlQueryContext.InvokeXsltLateBoundFunction(String name, String namespaceUri, IList`1[] args)
    at (XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at Root(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at Execute(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlSequenceWriter results)
    at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter writer)
    at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, XmlWriter results, XmlResolver documentResolver)
    at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, TextWriter results)
    at umbraco.presentation.webservices.codeEditorSave.SaveXslt(String fileName, String oldName, String fileContents, Boolean ignoreDebugging)
    Hope that someone can explain it for me :-)
  • Mike Chambers 636 posts 1253 karma points c-trib
    Jan 16, 2013 @ 15:25
    Mike Chambers
    just add a check
    <xsl:if test="number($currentPage/testBillede) &gt; 0">
    it's just alerting you to the fact that as testBilleded could well be empty or not an int...
    Jan 16, 2013 @ 15:31
    Kate
    Do you mean like this:
     </xsl:if>
    That still gives me an error
    I thourght I did check by doing like this:
    <xsl:iftest="$media != ''">
    Jan 16, 2013 @ 15:35
    Kate
    If I just have this in my xslt it still fails:
    <xsl:stylesheet
    version="1.0"
    </xsl:template>
    </xsl:stylesheet>
    Jan 16, 2013 @ 16:10
    Kate
    Okay, I got it :-)
    <xsl:if test="$media">
    </xsl:if>
    </xsl:if>
    </xsl:template>
    Thanks Mike
    Sorry, it took me a while to figure out what you meant :-)
