Content Type item not showing when creating content in "Business Site" folder
I've already seen the "Document Types" video, but still can't find "the checkbox" to enable creating content below the "business site" node. I have installed the business starter kit.
I know that the business home page tamplate is configured to this node, and that this template accepts another "business homepage" content type as a node. That's why I'm not able to see why any kind of content type is showing in the drop down when I try to create content.
From what you're writing above I think you misunderstand the terminology in Umbraco. (If I misunderstand what you're writing, then I'm sorry).
The items used for creating content nodes in the content tree are reffered to as "Document types".
Templates are simply masterpages (or views if using MVC) that contains your html markup.
Templates can be assigned to document types so we can display the content of a document type.
In order to be able to create a document node under your business homepage root node you need to go to the "Setting section" and then expand the "Document types" section.
On the "Business homepage" document type you should go to the "Structure tab". Here you can check those document types you want to be able to create when right clicking the "Business homepage" node in the content tree.
Thanks!
Hi Ariel and welcome to our :)
Hope this makes sense.
Thank You Jan! :D
