  • Robin Nicholl 137 posts 277 karma points
    Jan 25, 2013 @ 16:35
    Robin Nicholl
    Public Access and load balanced installation
    I have a site running on 2 load balanced servers, with the admin part on another server (all set up as per one of Tim's videos, and running for a couple of years now).
    I have a page protected via login (set using Public Access from drop-down) that works fine.
    However, I need to add another, separate login area – and it's only working on the admin site, not the actual site seen by users on the load balanced servers. I've made sure that App_Data/access.config is synced between the 3 servers, but I'm not sure what else needs syncing: visiting the 'protected' page on the live site just takes you straight to the page without requiring a login.
    Help!!
    Jan 26, 2013 @ 00:43
    Robin Nicholl
    Well, it seems you have to make sure App_Data/access.config is synced across servers, recycle the app pool on all servers, and touch (and sync) web.config
