  • ianhoughton 281 posts 605 karma points c-trib
    Aug 26, 2009 @ 23:30
    ianhoughton
    Related links datatype missing settings
    When i click on the Related Links datatype I get the Name and Render control fields but nothing appears in the settings section. If I create a new datatype and select the Related Links control, then save, still nothing.
    Any ideas ??
  • Tom Maton 387 posts 660 karma points
    Aug 26, 2009 @ 23:44
    Tom Maton
    101
    Hi Ian,
    I dont actually think that there are any settings for the Related Link datatype.
    As you add the related links within the content section of the UI.
    What are you expecting to see here?
    Tom
    Aug 27, 2009 @ 00:19
    ianhoughton
    Its been a long day !! Never thought to actually use the control. Wasn't sure how it worked but it seems to be ok now.
  • Sander Houttekier 114 posts 163 karma points
    Sep 03, 2009 @ 13:48
    Sander Houttekier
    yes, there are no settings for this control
    however it would be nice to have some
    1 i can think of would be a limit ... lets say, the design only lets you add 4 links, then it would be nice to limit the control to 4 urls.
    now i solve this by adding a description in the label that only the first 3 will be used or something. tough its not as nice :)
