After making a small change to my server, the left hand pane in the admin area is completely blank for ALL sections regardless. The right hand pane works and the sections are showing but there is nothing at all in the jTree on the left.
I have checked all permissions. Site works and content is displaying when the site is browsed. No login issues, just a blank left pane. I'm pretty desperate to get this fixed.
No browser errors, site works fine apart from blank left hand pane. Version 4.11.2
Change to VPS was the hostname through Plesk. Shouldnt have affected things but it did reset all the permissions in IIS including removing all the site bindings for all my websites.
I manually went through all the permissions and settings for all sites and got them all working again. Apart from that issue.
I know this isnt the solution but I did the following:
Backed up the site files, Replaced them with a clean version and ran the install against the sites DB.
Then I compared the files from the old site and added the templates, xslt and images from the backed up version. Republished the whole site to recreate the Umbraco.config. This worked. From here I will make packages from the sites just in case of any future issues. I will be upgrading to v6 pretty soon. All new builds are using v6 RC. I have 3 running it so far and all seems very stable.
I still dont know what caused the left pane to be blank in the admin area.
left hand pane blank in UI
Please can someone help?
Roger
Hi Roger
What was the change you made? And what version of Umbraco=
Do you get any errors in the browser console log? Have you checked if there is any information in the umbracoLog table that can be used for anything?
Hi Jan,
Hi Roger
Wow, that was really weird - but happy to hear you got it all working again though :)
Jan
