  • Garrett Fisher 341 posts 496 karma points
    Jan 28, 2013 @ 20:16
    Garrett Fisher
    FeedCache: File not Found Exception
    I've been using the FeedCache package for years now and love it but on a new environment recently I am getting the following error when clicking on any top-level folder on the Developer tab in Umbraco:
    Exception information:
        Exception type: FileNotFoundException
        Exception message: Could not find file 'C:\...\App_Data\TEMP\ExamineIndexes\Internal\Index\segments_fk79'.
       at Lucene.Net.Index.SegmentInfos.FindSegmentsFile.Run(IndexCommit commit)
       at Lucene.Net.Index.IndexReader.Open(String path, Boolean readOnly)
       at FergusonMoriyama.Umbraco.ExamineGui.Service.ExamineGuiService.NumberOfDocuments(String indexProvider)
       at ASP.usercontrols_indexstatus_ascx.__DataBind__control19(Object sender, EventArgs e)
       at System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding)
       at System.Web.UI.Control.DataBindChildren()
       at System.Web.UI.WebControls.Repeater.CreateItem(Int32 itemIndex, ListItemType itemType, Boolean dataBind, Object dataItem)
       at System.Web.UI.WebControls.Repeater.CreateControlHierarchy(Boolean useDataSource)
       at System.Web.UI.WebControls.Repeater.OnDataBinding(EventArgs e)
       at FergusonMoriyama.Umbraco.ExamineGui.UserControls.IndexStatus.Page_Load(Object sender, EventArgs e)
       at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e)
       at System.Web.UI.Control.LoadRecursive()
       at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
    This error comes along with a YSOD.  Anyone ever seen this before or have any idea what this might be?  I am apprehensive about manually placing any fles into the highly environmental App_Data folder.  I put FeedCache in the title of this post only because I see Ferguson Moriyama in the error.
    Garrett
