  • Stephen 767 posts 2273 karma points c-trib
    Jan 30, 2013 @ 15:37
    Stephen
    What shall we do with AltTemplate?
    At the moment in 4.11 and 6.x we disable altTemplate as soon as we're not displaying the document that exactly matches the url, either because of internal redirects, or because there was no document with that url and we're displaying the 404 page, or because there was a document but you don't have access to it and we're displaying the login page, whatever.
    Do you feel this is appropriate? Do you have a different opinion?
    Stephan
  • Jeroen Breuer 4908 posts 12265 karma points MVP 5x admin c-trib
    Jan 30, 2013 @ 15:41
    Jeroen Breuer
    If it's an internal redirect I think the AltTemplate should still be enabled.
    Jeroen
    Feb 27, 2013 @ 09:48
    Jeroen Breuer
    Has a decision already been made about this?
    Jeroen
    Feb 27, 2013 @ 10:48
    Stephen
    No decision, so 6.1 will by default _not_ enable the alt template on internal redirect, but come with a config option to re-enable it.
    Feb 27, 2013 @ 10:50
    Jeroen Breuer
    If it can be enabled with a config that's perfect :-).
    Jeroen
  • Sergey 5 posts 25 karma points
    Feb 27, 2013 @ 14:20
    Sergey
    But what about backward compatibility? Does that mean that if i upgrade my website that uses ?altTemplate feature to v 4.11 or v6 it will not work anymore?
    May 30, 2013 @ 17:30
    Jeroen Breuer
    Now that 6.1 is out what is the config option where we can change this?
    Jeroen
    May 30, 2013 @ 17:38
    Stephen
    2
    You need to declare a web.config section:
    <sectionGroup name="umbraco">
        <section name="web.routing" type="Umbraco.Web.Configuration.WebRouting,umbraco" requirePermission="false" />
    </sectionGroup>
    And then set the config (also in web.config):
    <umbraco>
        <web.routing internalRedirectPreservesTemplate="false" />
    </umbraco>
    And then it should work. An internal redirect should not reset the altTemplate anymore.
    Let me know if that's OK!
    May 30, 2013 @ 19:02
    Hi Stephen
    Dummy question here...why are these settings not just default in the web.config? Is it because it has a concequence wether you're running MVC mode or not?
    May 30, 2013 @ 19:03
    Stephen
    Not sure I understand... what do you mean by "not just default in the web.config"?
    May 30, 2013 @ 19:13
    From the previous post it sounds like one needs to declare the the stuff in the web.config manually - or do I misunderstand? Will these secions be in the web.config by default and then it's just a matter of setting internalRedirectPreservesTemplate="false" to "true" in order to enable it?
    May 30, 2013 @ 19:16
    Stephen
    Ah... yes you need to declare the stuff in web.config... and it's not already there. I guess the goal is to have it by default (now I see what you mean) and then you can change the settings. However, I understand we want to refactor how settings work for v7 and this is a rather "confidential" config (ie it was create for Jeroen, really) so it's not by default in web.config.
    But, to answer your question: not yet. Should be.
    Jun 03, 2013 @ 11:01
    Jeroen Breuer
    I just downloaded 6.1.1 and in the umbracoSettings.config I found internalRedirectPreservesTemplate="false". Do I still need to do all those web.config changes or can I just set it to true?
    Jeroen
    Jun 04, 2013 @ 11:23
    Stephen
    Internally we use UmbracoSettings.For<WebRouting>().InternalRedirectPreservesTemplate which, if the new web.config /umbraco/web.routing section is present, will use its value. Otherwise it will fall back to using UmbracoSettings.InternalRedirectPreservesTemplate which gets the value of /settings/web.routing/@internalRedirectPreservesTemplate from within umbracoSettigns.config.
    So you can just set it to true in umbracoSettings.config.
    The joy of migrating to new solutions while remaining backward compatible...
  • wolulcmit 357 posts 693 karma points
    Jul 08, 2013 @ 17:32
    wolulcmit
    Hi Stephen,
    I've set internalRedirectPreservesTemplate="true" in config/umbracoSettings.config
    I have my alt template in Views/my-alt-template.cshtml
    but when have tried to surf up my alt template using /path-to-my-node/my-alt-templat
    I still get the umbraco 404 intentionally ugly page.
    (am using 6.1.2)
    Have I missed something obvious?
    Jul 08, 2013 @ 17:34
    Jeroen Breuer
    Did you also create it as a template in the umbraco backoffice? Only having it in the views folder probably isn't good enough.
    Jeroen
    Jul 08, 2013 @ 17:59
    wolulcmit
    Hi Jeroen,
    Yep, I've got it in the back office as well,
    Ah! found the problem
    the node I was using also happens to have an UmbracoUrlAlias
    so if I do this:
    /my-nodes-url-alias/my-alt-template
    I get the 404
    but if I do this:
    /my-nodes-parent/my-nodes-real-location/my-alt-template
    It Works!
    thats kind of awesome that you used to be able to use UmbracoUrlAliases together with alttemplates
    what would the easiest work around be? (I'm guessing its just not built to work that way)
    thanks
    - Tim
    Jul 08, 2013 @ 18:48
    Stephen
    Hey,
    At the moment (6.1) the pipeline runs those content finders:
    • One that will look for /path/to/page
    • One that will look for /path/to/page/template
    • One that will look for /alias
    But it does not run a content finder that would look for /alias/template. Mainly because that was not supported in the old, 4.x pipeline. But it should be fairly straightforward to implement such a finder, should you really need one. Probably just need a bit of copy-and-paste from the existing finders.
    Stephan
    Jul 09, 2013 @ 03:29
    wolulcmit
    Cool, sounds promising!
    is that something I can already do by configuration somewhere?
    if not, maybe I can add it as a feature request to http://issues.umbraco.org
    the site I'm working on is actually a 4.x project that I've upgraded to 6 and am converting my templates to Mvc. So I'm a bit confused that you say /alias/template wasn't supported in the old pipeline because for the site in question that's exactly how it used to work :) meaning that I don't think I had to do anything special in order to achieve it.
    - Tim
    Jul 09, 2013 @ 08:35
    Stephen
    Can do by configuration. You'll want to look at how the current finders are implemented, do your own, then register it via an ApplicationEventHandler... you'll want to have a look at http://www.zpqrtbnk.net/TheUmbraco6RequestPipeline.pdf to better understand. I would have done it already for you... but I'm more than busy at the moment. Feel free to ask questions, though.
    Jul 09, 2013 @ 08:42
    Stephen
    Jul 09, 2013 @ 15:58
    wolulcmit
    Hi Stephen, thanks for replying so quickly.
    I've read through the pdf but only about 5% of it makes any sense to me unfortunately ( the part about having a v5 moment especially struck a chord :)
    my first question is where do the current finders hang out?
    You had me all ears at 'copy-and-paste' but now I'm feeling full of inadequacy and self loathing for my inability to fathom ApplicationEventHandlers and public interface IUrlProviders :(
    - Tim
    Jul 19, 2013 @ 08:43
    wolulcmit
    Ok, another question....
    So I would need to add something like this in Global.asax ?
    public class CustomApplicationEventHandler : ApplicationEventHandler
    protected override void ApplicationStarting(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
    DefaultRenderMvcControllerResolver.Current.SetDefaultControllerType(typeof(MyCustomUmbracoController));
    base.ApplicationStarting(umbracoApplication, applicationContext);
    It's the next part that I dont get. (and probably have no hope of achieving)
    Writing my own Custom Umbraco Controller and having it look for an extra route (altTemplate) when UmbracoUrlAlias is used
    I've looked in the pdf quite a few times and in the Umbraco Source for anything that made sense to me or where the default finders might be to copy from.
    I guess these are relevant?
    https://github.com/umbraco/Umbraco-CMS/blob/a132f609d789a9984ebe123e7c30b9230851d603/src/Umbraco.Web/Routing/AliasUrlProvider.cs
    https://github.com/umbraco/Umbraco-CMS/blob/a132f609d789a9984ebe123e7c30b9230851d603/src/Umbraco.Web/Configuration/WebRouting.cs
    help please, anyone. my brain is melting.
    - Tim
    Jul 19, 2013 @ 21:07
    Stephen
    Will try to cool down your brain ;-) No, you don't want to write a controller. You want to write an IContentFinder. There are stuff in the PDF about IContentFinder, with sample finders and how to register them (using the resolver in an application event handler). Then you'll want to look at the original code for Umbraco.Web/Routing/ContentFinderByNiceUrl.cs, ContentFinderByUrlAlias.cs and ContentFinderByNiceUrlAndTemplate.cs... you'll want to take bits of both to create your own ContentFinderByUrlAliasAndTemplate.cs.
    Sorry I can't give you code here... I'm away on vacation with an unstable 3G network link and very little time... hope you'll find your way!
    But feel free to ask questions.
    Stephan
    Jul 24, 2013 @ 08:45
    wolulcmit
    I'm a bit confused but somehow have inadvertently solved this (perhaps because of my earlier hurried testing).
    switching internalRedirectPreservesTemplate back to false and making sure that when you reference your alt template that you dont add the trailing slash / then the alt template is found and works with both:
    /urlAlias/alt-template
    /real-path-to-node/node/alttemplate
    Related to this:
    http://our.umbraco.org/forum/templating/templates-and-document-types/28785-altTemplate-alias-with-trailing-slash
    but from reading that it sounds as though this issue had been addressed.
    I have
    <addTrailingSlash>true</addTrailingSlash> in my umbracosettings.config
    Ideally I would also expect it to work with the forward slash, but right now I'm so happy that it just works and I dont have to write any C# code :)
    thanks,
    - Tim
