It's unfortunately a known bug with Umbraco 4.9. There also is a nasty bug using the "Rollback" option in the context menu.
Therefore I encourage you to upgrade to the latest version - actually 4.11.4 from the nightlies here http://nightly.umbraco.org/umbraco%204.11.4/ build 57 is the latest - I should not be that long before 4.11.4 is released in stable.
Deleting Recycle Bin Items
hi,
I am running 4.9.0 and everyting I try to delete an item from the recycle bin I recieve the error (in firebug):
POST http://www.londonlaunch.com/umbraco/webservices/legacyajaxcalls.asmx/DeleteContentPermanently 500 (Internal Server Error)
All the file permissions are there :S
Little help? maybe a DB issue?
S
Hi SinkyPars
Hope this helps.
Thanks Jan,
Is it a simple update or should I update to all previsous versions before 4.11.4 also?
Many thanks
Scott
I suppose you could go straight to 4.11.4 since there is no changes in the database in the versions up till this one.
However I would probably go step by step as described in the documentation here: http://our.umbraco.org/documentation/Installation/Upgrading/ - Also read the general instructions here http://our.umbraco.org/documentation/Installation/Upgrading/general
Hope this helps.
Alas the same problem exists when I upgrade, I have a feeling this is down to lecene indexes :(
