I have a specific problem on my umbraco. Tree control on umbraco UI dont't load data (any tree, such as items of Media, Content, Developer sections...) - showing only header (Media, Content...), also won't load context menu on this trees. Nothing in log or any warning messages. I can't remember after what this happend. Database is "visible" for the site.
But! All site works perfectly. Site have usercontrols which loading nodes over umbraco API - it's working.
I restore backup from 10 days ago and it works! So I put new usercontrols, masterpages, xslt... to this version and all works fine. Database I doesn't change. All OK!
Can someone please help me out of the same situation. I moved the entire Umbraco site from one unstable server to a stable server. But now Umbraco backside is broken. No nodes are loaded! :-(
I have uploaded a patch to codeplex ID: 7083, that contains the code + a release build of the umbraco.datalayer.dll, also the MySQL scripts can be run manually
Problem with tree in umbraco UI
Hello!
Why umbraco UI won't work? Any ideas?
Umbraco 4.0.1
MsSQL 2005
ASP.NET 3.5
IIS 7
Maybe the solution here can help: http://our.umbraco.org/forum/getting-started/installing-umbraco/3768-Nodes-empty-and-null-message
I have deleted files from those folder but nothing happens :(
Did you also run umbraco/reindex.aspx after you deleted the files? (After that you should see new files in that directory again)
Yes, I did, but no effect
Thanks for replies.
See: http://our.umbraco.org/forum/core/general/3945-Content-Tree-not-loading?p=1#comment49105
