  • Edwin van Koppen 156 posts 270 karma points
    Jan 31, 2013 @ 12:33
    Edwin van Koppen
    SurfaceController to make a menu?
    Hi all,
    I want to make a menu in a childaction so i can add this to the _layout.cshtml. How do i do this? If i want to use CurrentPage in a ChildAction i get: "Can only use UmbracoPageResult in the context of an Http POST when using the BeginUmbracoForm helper".
    Do any of you got a example how to make a menu in Umbraco with a surfacecontroller? Or how do you build a menu?
    p.s. i got multiple domains with different languages so i can't just take the rootnode and go from there..
