  • Rodske 74 posts 104 karma points
    Aug 28, 2009 @ 06:04
    Rodske
    Strange login error
    <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} span.EmailStyle15 {mso-style-type:personal; mso-style-noshow:yes; mso-ansi-font-size:10.0pt; mso-bidi-font-size:10.0pt; font-family:Arial; mso-ascii-font-family:Arial; mso-hansi-font-family:Arial; mso-bidi-font-family:Arial; color:windowtext;} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} -->
    Irrespective of user account, user privilleges on IE6 and unusual error consistantly occurs for several content editors when they attempt to log in.
    Any ideas or pointers on the error below?
    At /umbraco/umbraco.aspx (Referred by: /umbraco/login.aspx?redir=/umbraco/umbraco.aspx):
     System.ArgumentOutOfRangeException: Value to add was out of range.
     Parameter name: value     at
     System.DateTime.Add(Double value, Int32 scale)
     at umbraco.cms.presentation._umbraco.Page_Load(Object sender, EventArgs e)
     at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e)
     at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e)
     at System.Web.UI.Control.OnLoad(EventArgs e)
     at umbraco.BasePages.BasePage.OnLoad(EventArgs e)
     at System.Web.UI.Control.LoadRecursive()
     at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
  • Chris Koiak 700 posts 2626 karma points
    Aug 29, 2009 @ 09:29
    Chris Koiak
    Looks like a date issue. I assume your server's date is set correctly?
