I have 2 sites on the same installation of Umbraco. I also have flat URL's. The problem is that the flat URL's seems to be shared between the sites.
Example;
SIte1 - Home - About
Site2 - Map- Places
So if I type Site1/map I would expect a 404, but no, I get Site2/map, with the domain still from Site1.
The sites;http://gilimeno.orghttp://adeng-adeng.com
in umbracosettings.config try changing this value
<!-- this will ensure that urls are unique when running with multiple root nodes --> <useDomainPrefixes>false</useDomainPrefixes>
/Jesper
... to true .-)
Hey it worked!Many thanks for the fast response.
(I had to restart the IIS for some reason before it kicked in.)
most welcome (please remember to mark the response as a solution, so others easily can find it )
Upload image
Problem with multiple sites, flat URL gets shared
Example;
SIte1
- Home
- About
Site2
- Map
- Places
The sites;
http://gilimeno.org
/Jesper
... to true .-)
Hey it worked!
/Jesper
