Hi everyone,
I just finish UI translation completion for backoffice in french throught the
/Umbraco/config/lang/fr.xml
file and would like to contribute it for the community.What is the best way to achieve that :
P.S : I just notice that the Similar topic box on the right conatins links that are all pointing on a create new topic page.
Thanks for your remarks / comments.
David
Hi David
How nice of you! You rock :)
I think you should actually create a pull request - You can read more about how to contribute to the core here http://our.umbraco.org/contribute/guidelines-for-core-contribution and how to work with the source here http://our.umbraco.org/contribute/working-with-the-umbraco-source
Hope this helps and somebody corrects me if this is overkill.
Cheers,Jan
Just asked Sebastiaan Janssen and actually you can make a fork of this project and make a pull request https://github.com/umbraco/Umbraco-4-Localization
Hi Jan,
Thanks for the quick response.I've made the pull request so hope may be it will be present in the next version.Thanks you for your quick response and keepup the good work.
Cheers
French UI Translation
Hi everyone,
David
Hi David
Jan
Hi David
Hi Jan,
Cheers
David
