  • Roma 4 posts 24 karma points
    Feb 06, 2013 @ 15:16
    Roma
    User permissions - not showing current status
    I have setup a user to have access only to certain areas of the website. When I go back to edit the user's permissions I do not see what is currently selected for that users.
    my umbraco version is 4.7.2
    Any suggestions?
    R
    Feb 06, 2013 @ 19:12
    Hi Roma
    Could you perhaps post a screendump of the issue you mentioned above? I'm not sure I quite understand it :)
    Feb 06, 2013 @ 20:53
    Roma
    the first screen shot is when i am applying the permission to a specific user...
    after i click on OK i get the Saved message .. I then navigate away from this page to any other page and when i return this is what i see for the same user..
    i would expect to see that the "fr" node is checked and showing the current permissions applied to this user.
    Thanks for the help,
    Roma
    Feb 06, 2013 @ 20:59
    Hi Roma
    Aaah, now I see...
    So if you click the "fr" node you can actually still see what permissions the user has for this particular node, right?
    I agree that the UX stinks a bit here and hopefully this is some of the stuff that will be adressed once the Umbraco Belle project really kicks off.
    Jan
    Feb 06, 2013 @ 22:24
    Roma
    Yes you are right .. if I click on the "fr" node I do see the currect permissions.
    that means when I click on "en" i should see no permissions set ...... which is not the case :)
    This is confusing for the user, because they think the permissions are not exclusive.
    R
