  • Pacoss 9 posts 29 karma points
    Feb 06, 2013 @ 17:22
    Pacoss
    publishing multilanguage site
    hi
    i'm new in creating umbraco sites, so as expected, have problems :)
    i created multilanguage site by watching tutorials ... so my site has two home nodes, home1 (english) and home2 (croatian). as seen in video i have to manage hostnames, which i did. say, for home1, hostname is enghome (http://enghome/), and for home2 is crohome (http://crohome/). after republishing entire site i can't run site in my browser. before managing hostnames i was using only home1 which had the following link: http://localhost:58466
    also tried http://enghome:58466, but no success.
    so, i would like if anyone could tell me what to do to run this site and how to publish it locally on iis.
    thanks in advance!
    Feb 06, 2013 @ 19:08
    Hi Pacoss and welcome to our :)
    I suppose you're using IIS express and I must admit I can't remember how it is you manage hostnames (if at all) in this version.
    I suggest you start IIS7 and create a new website that you map to your Umbraco root folder - then you can add the bindings for the site and you should be able to access both your sites.
    See the "Using IIS" section in the documentation here: http://our.umbraco.org/documentation/Installation/install-umbraco-manually
    Hope this helps.
    Feb 07, 2013 @ 13:57
    Pacoss
    thanks for help
