While selecting custom styles in richtext editor it is firing js error as follow:
Is it possible that the alias name of the style is not right?
Specifically, if we define a class, the alias must be preceded by a dot (.) And must not contain spaces
Name: my dazzling style
Alias: .MyDazzlingStyle
In umbraco you must manually edit the alias and the dot is easy to forget
Yes you are absolutely right.. I forgot the dot..
thanks for reply
Regards Tri
Upload image
Problem in tinymce3tinymceCompress in version 4.11.4
thanks for reply
Regards Tri
