  • sundip 76 posts 339 karma points
    Feb 11, 2013 @ 16:30
    sundip
    RTE not updating the content after publish
    Sorry, if I am in a wrong section.
    I am trying to update an existing website which has 'RTE' as a content placeholder. After editing the rich text editor if I publish the page the content remain the same as before, no changes.
    What could be the reason?
    Thanks for the help.
    Sundip
    Feb 11, 2013 @ 19:10
    Hi sundip
    Can you tell us a bit more about the version of Umbraco you're using? And have you double checked that the macro does not have any caching set? (If you're using a macro).
    Have you also checked that permissions are still correct? Do you by any chance run a multisite setup?
    Looking forward to hear more from you.
    Feb 11, 2013 @ 19:12
    sundip
    Hi Jan,
    I am using version 4.7.1
    Not using any macros, just html and text.
    What permissions do I need for this? I think I have full.
    This is single site.
    Thank you for replying,
    Sundip
    Feb 11, 2013 @ 19:18
    Hi Sundip
    Ok, what does the code in your master-template look like?
    Feb 11, 2013 @ 19:20
    sundip
    Feb 11, 2013 @ 19:28
    Hi sundip
    Ok that look right.
    And yes full permissions should be enough...what happens if you recycle the app pool? Does the content changes then display?
    Feb 11, 2013 @ 19:29
    sundip
    Let me try to do that and check the permissions again with my admin, will get back to you.
    Thank you.
    Feb 12, 2013 @ 17:22
    sundip
    Hi Jan,
    Sorry for the trouble above, that perticular RTE is using Macro, I was not able to identify that.
    Thanks for help.
    Sundip
