  • Emil Christiansen 66 posts 148 karma points
    Feb 12, 2013 @ 07:57
    Emil Christiansen
    Problem deleting single node from recycle bin
    Hi there!
    I am having a problem deleting one of the nodes in the recycle bin. If i right click the node and click delete - nothing happens. The node changes name to "deleting..." but it doesn't disappear.
    Is far as i can see, the problem is that the parent node no longer exist. If i try to move the node, i get an "No node exists with id '2123'" - the node which i am trying to delete has id 2191, and 2123 is the parent node that no longer exist.
    All other nodes in the recycle bin can be deleted.
    Is there anything i can do? We have upgraded to the latest Umbraco 4.11.4 with the Path Fix.
    Thanks in advance!
    Feb 12, 2013 @ 08:01
    Hi Emil
    Try having a look at this SQL example - This should do the trick.
    http://spyriadis.net/2012/06/umbraco-fix-empty-recycle-bin-using-sql-if-backend-fails/
    Feb 12, 2013 @ 08:37
    Emil Christiansen
    I have seen many of those SQL queries regarding the recycle bin. The problem is that they all differ from each other, and almost everyone of them has a 'not sure if this breaks anything' over it. I just don't want to break anything because I have deleted something I shouldn't in the database :-)
