I am trying to use the Microsoft Translater to create at multi langual site as shown by Per Plough Hansen (http://umbraco.org/blog/2009/3/25/microsoft-translator-and-umbraco). My problem is that when i try to copy my main node i get an error as seen below. I have also tried copying single nodes but the same error occurs. I am new to umbraco and does not know from where this error could originate...any ideas? (I am using Umbraco 4.0.2.1 at my webhost: unoeuro.com)
Regards
Tarrild
Source Error:
Stack Trace:
umbraco.cms.businesslogic.relation.Relation.MakeNew(Int32 ParentId, Int32 ChildId, RelationType RelType, String Comment) +173
umbraco.cms.businesslogic.web.Document.Copy(Int32 CopyTo, User u, Boolean RelateToOrignal) +369
umbraco.dialogs.moveOrCopy.HandleDocumentMoveOrCopy() +1499
umbraco.dialogs.moveOrCopy.HandleMoveOrCopy(Object sender, EventArgs e) +51
System.Web.UI.WebControls.Button.OnClick(EventArgs e) +111
System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +110
System.Web.UI.WebControls.Button.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +10
System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +36
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1565
Version Information: Microsoft .NET Framework Version:2.0.50727.3074; ASP.NET Version:2.0.50727.3601
Error when copying content node
Regards
Tarrild
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Have you been able to copy node before? Can you copy the nodes if you remvoce the .cs file form the app_code folder?
