  • D-au 26 posts 76 karma points
    Feb 18, 2013 @ 03:33
    D-au
    Umbraco template error
    Hi guys,
    I'm using umbraco 4.52 on NET4 at the moment. Everything works fine and I have manage to create quite a decent website out of it. But at this point of time umbraco has crashed on me as I can't open any of the nodes/content-pages on the cms and also templates. It all started when my umbraco starting to SAVE templates slowly. It just then getting slower and slower until it got to the point of giving an error "Could not save template with the same name" instead of saving. After logging out and logging back in, I am now stuck not being able to edit content & template as umbraco keeps loading without producing any result.
    Any ideas what I should do at this point?
    Feb 18, 2013 @ 13:01
    Jeroen Breuer
    Why are you using 4.5.2? That's a pretty old version. Might be better to upgrade to 4.11.4 or 6.0.0 to see if that fixes the problem.
    Jeroen
    Feb 18, 2013 @ 23:24
    D-au
    Thanks Jeroen, it turns out, it is a server issue. The site has fixed itself. But I'll definitely try out 4.11.4 later on in the future. The reason I was avoiding the later version is because I'm still using the old schema. Does 4.11.4 / 6.0.0 still give you that option to switch schema?
