Hi. The only thing I can come up with at once is creating a custom data type with a blank editor control. You could grub the sources of the existing Label datatype from the umbraco sources and modify them slightly just to remove the visible label itself.
how to hide a property in umbraco 4.7.1.1
how to hide a property in the document in umbraco 4.7.1.1
I see this is an old post, but you still might need this :) Check this solution http://dejanstojanovic.net/umbraco-cms/2014/may/hide-property-in-umbraco/
