I am very close to having a Macro/XSLT create a drop down navigation menu. (I am new to XSLT)
Using the following XSLT, I am unable to get the "Home" node added to the navigation menu. How is it that I can add the Home link like the default
My desired HTML is as follows:
<nav> <ul> <li ><a href="/">HOME</a></li> <li><a href="#">Link 2</a> <ul> <li><a href="#">Link 2.1</a></li> <li><a href="#">Link 2.2</a></li> <li><a href="#">Link 2.3</a></li> </ul> </li> <li><a href="#">Link 3</a></li> </ul> </nav>
My current XSLT is as follows:
<xsl:output method="xml" omit-xml-declaration="yes"/> <xsl:param name="currentPage"/> <!-- update this variable on how deep your site map should be --> <xsl:variable name="maxLevelForSitemap" select="3"/> <xsl:template match="/"> <nav> <xsl:call-template name="drawNodes"> <xsl:with-param name="parent" select="$currentPage/ancestor-or-self::* [@isDoc and @level=1]"/> </xsl:call-template> </nav> </xsl:template> <xsl:template name="drawNodes"> <xsl:param name="parent"/> <xsl:if test="umbraco.library:IsProtected($parent/@id, $parent/@path) = 0 or (umbraco.library:IsProtected($parent/@id, $parent/@path) = 1 and umbraco.library:IsLoggedOn() = 1)"> <ul> <xsl:for-each select="$parent/* [@isDoc and string(umbracoNaviHide) != '1' and @level <= $maxLevelForSitemap]"> <li> <a href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="@nodeName"/></a> <xsl:if test="count(./* [@isDoc and string(umbracoNaviHide) != '1' and @level <= $maxLevelForSitemap]) > 0"> <xsl:call-template name="drawNodes"> <xsl:with-param name="parent" select="."/> </xsl:call-template> </xsl:if> </li> </xsl:for-each> </ul> </xsl:if> </xsl:template> <xsl:template name="drawLevel1"> </xsl:template>
The default umbTopNavigation uses the following to add the Home link, but i get an error when trying to add it after the opening <nav>:
<li class="home"> <xsl:if test="$currentPage/@id = $currentPage/ancestor-or-self::* [@level=$level]/@id"> <xsl:attribute name="class">home current</xsl:attribute> </xsl:if> <a href="/">Home</a> </li>
Any thoughts?
XSLT Dropdown Menu: how to add a "Home" link?
<nav> <ul> <li ><a href="/">HOME</a></li> <li><a href="#">Link 2</a> <ul> <li><a href="#">Link 2.1</a></li> <li><a href="#">Link 2.2</a></li> <li><a href="#">Link 2.3</a></li> </ul> </li> <li><a href="#">Link 3</a></li> </ul> </nav>My current XSLT is as follows:
<li class="home"> <xsl:if test="$currentPage/@id = $currentPage/ancestor-or-self::* [@level=$level]/@id"> <xsl:attribute name="class">home current</xsl:attribute> </xsl:if> <a href="/">Home</a> </li>Any thoughts?
