  • Fuji Kusaka 2203 posts 4220 karma points
    Feb 20, 2013 @ 10:48
    Fuji Kusaka
    Search Phrase / different words using examine
    Hi Guys,
    I have a examine index search under v 4.9.1 and facing some issues whenever i search of some words like for example "Hello World" which will return "zero" but if look for "Hello" or "World" seperately it returns some values.
    Under node content i have a document type textbox where client will be able to add the keywords for his search to work. Having checked with lucene the indexes i actuallly do have both "Hello" and "World" being indexed.
    Is there a way of getting the results for single and double words or even longer ones in examine ? The project being done has some important name such as "Rooms .... " or "Rooms ....", so search is always null when i type  "Rooms...." followed by some other keywords.
    Here is my code
    @using umbraco.MacroEngines;
    @inherits umbraco.MacroEngines.DynamicNodeContext
    @using Examine
    @using Examine.SearchCriteria
    @using Examine.LuceneEngine.SearchCriteria
        var searchTerm = Request.Form["serachTerm"];
        var list = 0;
        //Check if SearchQuery is Null
       if(String.IsNullOrEmpty(searchTerm)){
           <p>@umbraco.library.GetDictionaryItem("Please Search")</p>
           return;
        var searcher = ExamineManager.Instance.SearchProviderCollection["HRSearcher"];
        var searchCriteria = searcher.CreateSearchCriteria(BooleanOperation.Or);
        var query = searchCriteria.Field("umbracoNaviHide", "1").And().GroupedOr(new string[] { "bodyContent", "metaKeywords", "metaDescriptions", "altPageTitle", "petitPlus", "fileIndex" }, searchTerm.Fuzzy(0.5f)).Compile();
        var searchResults = searcher.Search(query);
        var noResults = searchResults.Count();
        <p> @umbraco.library.GetDictionaryItem("SearchTxt") <strong><u>@searchTerm</u></strong> @umbraco.library.GetDictionaryItem("Search Found") @noResults  @umbraco.library.GetDictionaryItem("Search Results")</p>
       <div id="searchMnu">
        <ul>
            @foreach (var result in searchResults)
                list++;
                if (@result.Fields["nodeTypeAlias"] == "File")
                    var media = @result.Fields["parentID"];
                    var category = Model.MediaById(media);
                    dynamic mediaItem = new DynamicMedia(result.Id);
                    <li onclick='window.location="@mediaItem.umbracoFile"; return false;'>
                      <span> @list. @umbraco.library.GetDictionaryItem("telecharger")  @result.Fields["nodeName"]</span>
                    </li>
                    if(@result.Fields.Keys.Contains("bodyContent")){
                         <li onclick='location.href="@umbraco.library.NiceUrl(result.Id)"'>
                              <span> @list.  @result.Fields["nodeName"]</span><br />
                                     @Library.Truncate(@Library.StripHtml(result.Fields["bodyContent"]), 200)
                             </li>
                else{
                    </li>
        </ul>
    Any Advice on how to proceed here ?
    //fuji
    Feb 25, 2013 @ 07:05
    Fuji Kusaka
    Any Help on this please? or should i conside using xslt search instead ?
