How have you setup hostnames on your sites? And what version of Umbraco are you running?
We have a site on 4.7 where the above scenario works just fine - have not checked in newer versions yet but I would be puzzled if it does not work. However this can easily be a setup issue somehow.
issue with RTE Node Picker in multilingual website
I noticed, that when using the Node Picker in RTE to make a link, the link references to homepage of the language version:
www.mymultilanguagesite.com/he.aspx#
When I look at to html markup in RTE, the link looks fine:
<a href="/{localLink:1703}" title="Energy Efficiency Area">
Did anyone else experience this behaviour?
At the moment, I can't make a link in RTE from my homepage to another node in my multilanguage website.
thanks for your help,
Anthony
Hi Anthony
Looking forward to hearing from you.
