I can't upgrade because I'm not a developer. The website template is very old and I've been told that if I try to upgrade I will break the template.
I've had a lot of trouble deleting items in the recycle bin (there were over 4000 of them) but after restarting the IIS server I was able to do it.
However, now when I delete an item from the website, it doesn't appear in the recycle bin. All I see in the recycle bin now is an empty folder called 'content'. What have I done wrong? Could there be a file missing somewhere?
THat seems like a very odd behaviour. Do you by any chance know if there has been made some custom logic interacting with the Umbraco API that could be the cause of this?
Do you see any errors in the console log of the browser you're using when deleting a node?
Thanks for your reply. You are right, there was a file missing. I restored it from our backup and now the recycle bin is working as expected. It seems the file was deleted when we restarted the IIS server!
Deleted items don't appear in recycle bin
HI, my umbraco version is umbraco v 4.0.4.2
Hi Margaret and welcome to our :)
Looking forward to hearing from you.
Hi Jan,
