    Feb 21, 2013 @ 10:25
    Anthony Candaele
    issue with Client Depency Framework
    I just implemented the Client Depency Framework in the master template of my website.
    It works fine on my development machine, but for some reason some styles are not rendered on my production machine.
    Does someone has an idea what could be going on?
    Thanks for your advice,
    Anthony
    Feb 21, 2013 @ 11:30
    Rich Green
    Hey Anthony,
    Did you try bumping the number? I can't remember exactly how to do this, but I think all the caching would need to be 'redone' on the production machine in the first instance, as the site would be expecting the cached data to already be there.
    Just a stab in the dark...
    Rich
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Feb 21, 2013 @ 12:26
    Jeroen Breuer
    Does it work if you run the production machine in debug mode? In debug mode CD doesn't compress so it should work normal. If it doesn't that's probably where the problem is.
    Jeroen
